It is currently Tue May 19, 2026 7:38 pm
PostPosted: Fri Mar 16, 2018 2:24 pm
Car Model: 73 PLYMOUTH DUSTER 3.7 225L
I have a 73 Duster 3.7 225, I've rebuild the trans and engine she runs good she can be great, but my problem is that i'm having problems finding a affordable A/C brackets or sit for my car can anybody help me out, I'm in the Houston area and the HEAT is turning up fast !!!!!!!
PostPosted: Fri Mar 16, 2018 2:34 pm
1BBL
PostPosted: Fri Mar 16, 2018 2:38 pm
Welcome to the board. Did this car originally have A/C and you are missing parts to get the system put together and up and running? Or you're starting with a non-A/C car and want to add air conditioning?
PostPosted: Fri Mar 16, 2018 3:28 pm
my car have a/c just need to find the brackets to convert into the newer compressor
PostPosted: Fri Mar 16, 2018 4:48 pm
The bracket kits available to do so are poorly engineered and tend to create problems.
Why do you "need" to convert to a different type of compressor?
PostPosted: Fri Mar 16, 2018 5:28 pm
80s era slant six powered Dodge trucks and vans were built with the later Sanden style AC compressors. Late 70s and early 80s cars were too. You should be able to retrofit those brakcets to an earlier car. I recommend trying to get the brackets out of a van since those are designed for a smaller engine bay.
PostPosted: Wed Mar 21, 2018 11:24 am
Contact member Charlie_S. He makes kits for the conversion and can help you out.
PostPosted: Wed Mar 21, 2018 1:26 pm
SSRN National Champion
Charlies kits are spot on. I have used two or three of them.
Users browsing this forum: Amazon [Bot], Google [Bot] and 14 guests
