It is currently Tue Jun 16, 2026 1:48 pm
PostPosted: Mon Apr 26, 2004 5:35 pm
Any of you guys ever use the Offenhauser Dual Carb intake? Is it better just to get a super six 2bbl intake. I was thinking of putting headers on it also.. let me know what you guys think.. thanks~!
PostPosted: Mon Apr 26, 2004 6:50 pm
The twin 1bbl setup works well IF you take the time and effort to find, build and install a set of MATCHED carburetors. The choke problem is easily solved in any of several good ways.
Don't use headers, use Dutra Duals instead.
PostPosted: Tue Apr 27, 2004 7:06 am
If you are thinking about a dual carb setup, you should consider the package that Chris at Pro Line Fuel is selling:
http://www.prolinefuel.com/dualslant.html
and
http://www.prolinefuel.com/customers.html
I think the dual Webers would perform better than a single 4bbl carb and look a lot more impressive. You would have trouble trying to do the same on your own because Chris buys unfinished manifolds from Offenhauser and machines them to fit the Weber carbs.
Also, the 1bbl Carter BBS carbs that this manifold was designed for used the old-style shaft linkage. If you use those carbs with a cable throttle linkage you will have to do some creative fabrication. I expect the later Holley 1bbl carbs would work fine but I don't know for sure. The super six setup would be the simpler and cheaper way to go, especially for later model slants.
 Post subject: Frank....
PostPosted: Tue Apr 27, 2004 12:06 pm
They would work better in theory, but Chris's setup is non-progressive, so as you tromp the pedal, you open all 4 bores at the same time...where as with the 4 barrel the secondaries will only open on demand. That will change quite a bit when Chris R&D's a progressive setup (synchonis)...
It is a great setup and pretty much plug and play, though.
PostPosted: Wed Apr 28, 2004 6:45 am
As I haven't tried the ProLine dual carb intake, I can't say for sure how well it works. However, I have read postings from others who have installed it and they sound quite pleased with it. None of the feedback mentioned any sort of bog on acceleration.
 Post subject: Kickdown?
PostPosted: Wed Apr 28, 2004 9:13 am
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
With the dual Webbers, do you use the stock kick-down linkage for a Super Six? I couldn't figure it out from the photos on the links supplied. Sure looks like a nice set up.
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Wed Apr 28, 2004 9:23 am
Hey all,
Defiantely interested in someone who might be interested in trying to Alpha test a progressive set-up, it would be with 32/36 DGEV carbs.
As for kickdown on this set-up, it requires modification/fabrication. Doug had a link to a bunch of good pics showing his set-up, but I cant find it. Help?
Thanks
Chris
ProLineFuel.com
PostPosted: Wed Apr 28, 2004 6:02 pm
I might be interested in a triple carb SU setup sometime down the road. But where and how?
PostPosted: Wed Apr 28, 2004 6:29 pm
i would be interested.it would be on a 83 ram,manual tranny.cost?
there is only one...
PostPosted: Wed Apr 28, 2004 6:40 pm
Triple carb SU:
Lynx (Australian mfg.)
U.S. Distributors:
carbs.net
ramflo usa
Sorry Chris... The man asked for SU carbs :(
My truck is a Frankenstein creation
Built from the dead carcasses of others
And brought BACK TO LIFE!
PostPosted: Wed Apr 28, 2004 9:59 pm
...Doug had a link to a bunch of good pics showing his set-up, but I cant find it. Help?
Thanks
Chris
ProLineFuel.com
Here is a link to all the pics I shot when I did the Proline installation on my 65 Dart.
http://www.dutra.org/doug/draft-webpages/pro-line/
This is just a directory of photos, I need to find some time to finish-up this web page. (I have a good "step-by-step" write-up just no time to do the final webpage)
PostPosted: Thu Apr 29, 2004 9:17 am
Hey, if Chris has a kit available Id be glad to talk to him, being US-based, turnaround time would probably be faster! :)
How about the conventional Weber setup in a triple carb?
PostPosted: Fri Apr 30, 2004 8:12 am
SU's ? Well If you can come up with a triple sidedraft manifold I would go with DCOE's ( I dont think you'll have any luck with clifford, I just sold a LYNX (the only one I had a line on) intake to a guy who tried to get one from clifford for over a year)
DCOE's are getting very expensive tho' like $400 each !
As for a triple downdraft set-up, I cant think of an intake that could be machined for it... Ive considered casting intakes (triple sidedrafts at one time) but the cost was more than I could handle.
Doug thanks for the link!!!!
PostPosted: Fri Apr 30, 2004 8:26 am
I am considering motorcycle throttle bodies vs. a mustang throttle body on a plenum manifold with Megasquirt. I bring this up because there are other possibilites besides the Weber or Dell Orto side draft carbs, and I would be interested in a good triple sidedraft manifold, if I could find one for a reasonable price. If not, I may fab one up myself, or go with the plenum tube that should be pretty easy to fab up.
Chris, have you thought about using Megasquirt to sell FI kits?
