It is currently Sun Oct 25, 2026 3:26 pm
 Post subject: Head gasket
PostPosted: Thu May 31, 2018 2:39 pm
Where do you purchase a good head gasket for a race motor. The last one I purchased was from Cox Brothers and was a copper gasket. I know they haven’t been selling for slants and I will need one when I put my motor back together. Also will need freeze plug kit for this motor. Any help will be appreciated.
 Post subject: Re: Head gasket
PostPosted: Thu May 31, 2018 3:06 pm
What is your static compression ratio? Fel Pro is good up to about 11:1. The Aussie gasket (composition) is good to about 12:1.
PostPosted: Thu May 31, 2018 3:58 pm
Lou it is suppose to be 10 to 1 according to Gary Bruner who built the engine. Does felpro have a web site I can order from. Thanks Norm
PostPosted: Thu May 31, 2018 4:56 pm
Just order an engine rebuild kit, you get extra gaskets you may need later and the head gasket alone costs about 1/3-1/2
the rebuild kit. You can get them at Rock Auto, or order at Auto zone... FS7918PT-4 for the full gasket set at about $70...
Head gasket only... 7918PT-1 and is $23+
I used a felpro gasket on an 11:1 engine and it blew on a freshly milled flat deck and head... a number of killer bees
use the victor reinz gasket on their rides, I have fired off the 12.3:1 engine and no issues with that gasket...previously
switched tot he Reinz gasket on that 11:1 motor and had no problems with it.
PostPosted: Thu May 31, 2018 5:54 pm
If it is only 10:1, I think any gasket you can find will work fine. Victor should be available at any parts store (order 1-3 days?) or the Felpro.
PostPosted: Fri Jun 01, 2018 3:15 am
How big is the bore?
PostPosted: Tue Jun 05, 2018 10:04 am
IIRC, Jim still had an assortment of copper gaskets last March at the ICH Swap.
PostPosted: Tue Jun 05, 2018 7:47 pm
I trust any of these guys if they say the Fel-pro head gasket will work fine for your application, but if you're buying an entire engine gasket kit then I'd go ahead and step up to Victor Reinz to get a better manifold gasket. I've never gotten a Fel-pro manifold-to-head gasket to seal correctly. Any of these, as well as the expansion plugs, can be found on RockAuto.
If you're running a stock exhaust manifold, neither of those kits will have a good gasket for the heat riser box. I'd go with the Remflex gasket for that.
Escape Velocity Racing
Users browsing this forum: Amazon [Bot] and 7 guests
