It is currently Sun Sep 06, 2026 12:19 pm
 Post subject: Carter BBD adjustment
PostPosted: Tue May 04, 2004 10:00 pm
what should the vacuum reading be at idle for the BBD? Is there preferred jet size to achieve a balance of performance and MPG? If there is, how would I go about changing jets and where would I get them?
PostPosted: Wed May 05, 2004 12:40 am
Do you have the original SL6 BBD carb. or is it a BBD off a 318 V8?
Read thru this info. there are some adjustments you should check:
http://www.slantsix.org/articles/supers ... e-list.htm
