It is currently Tue May 19, 2026 7:37 pm
PostPosted: Wed Apr 21, 2004 12:24 pm
How different is the floor shift linkage/shift lever set up of a '61 Lancer and the set up in the early Valiants? The transmissions are the same, but would the Lancer set-up fit properly in a Valiant?
tim
 Post subject: For 3 speed manual
PostPosted: Wed Apr 21, 2004 9:30 pm
The 61 Lancer with the 170 engine and the 61 Valiant (only offered with 170) show all the same parts in my books in the shift linkage for the
3 speed manual.
The 61 Lancer with the 225 has one different part - the 1st and reverse shift rod.
PostPosted: Thu Apr 22, 2004 8:12 am
How about 62? Any changes?
PostPosted: Thu Apr 22, 2004 11:58 am
I don't think the floor shifter was available on the '62 valiant (which is why i had to cut a hole in the floor of mine. :D )
PostPosted: Sun Apr 25, 2004 11:55 am
@ crosleyhook:
Did you swap in a 4 speed ? I have a 62 Lancer 3onthetree and I can get a 4sp OD that I´d like to swap sometime, but found about zero information an floor humps, linkage and stuff... Any information appreciated!
Chris
PostPosted: Tue Apr 27, 2004 11:03 pm
This is a "doable" and worth-while swap.
You will have to cut a large hole in the floor.
You will have to use the OD 4-speed bellhousing and make a special pivot bracket to keep the clutch "bellcrank" in the correct position.
You will need a special speedo cable assembly (1966 A-body)
You will need a slip-in type driveshaft that will most likely need to be shortened.
PostPosted: Thu May 06, 2004 2:48 pm
Thanks Doc!
Great site, great people.
Without you, I´d be lost ...
Thanks!
Christian
