It is currently Fri Jun 19, 2026 12:31 am
PostPosted: Thu May 06, 2004 8:44 pm
because I was looking for some 340 valve springs on ebay and came across this
are they the same ? :?:
Brand new set of 16 valve springs for 318 340 360 Chrysler 2-bbl and any SB Mopar with stock or RV torque cam.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ename=WDVW
http://www.cardomain.com/id/lncognito
PostPosted: Thu May 06, 2004 10:37 pm
I believe the 340 springs are stiffer because the 340 was designed to be a high revving engine. Six thousand + rpm is nothing for a stock 340.
PostPosted: Sat May 08, 2004 6:34 am
The stock 340 springs are good for a cam lift of around .525". The springs you have listed there probably wouldn't do much more thn a stock Slant spring. :shock:
Users browsing this forum: Ahrefs [Bot] and 1 guest
