It is currently Thu Nov 12, 2026 5:00 pm
Post new topic  Reply to topic  [ 36 posts ]  Go to page Previous 1 2 3
PostPosted: Mon Nov 02, 2020 5:36 pm
PostPosted: Mon Nov 02, 2020 5:47 pm
https://www.slantsix.org/forum/viewtopi ... 4&start=45 last post at the bottom of this page seems to indicate a non-operating power enrichment system. Cruise and acceleration under low vacuum are both at the same air fuel ratio. No change
PostPosted: Mon Nov 02, 2020 5:54 pm
By 1977 even the heavy duty emissions trucks were using the new vacuum dump system for the power valve. Just beginning to dump vacuum Image
PostPosted: Mon Nov 02, 2020 6:00 pm
Wide open vacuum is completely dumped the spring is not fighting vacuum full force of a spring is available to open power valve. Image
PostPosted: Mon Nov 02, 2020 6:28 pm
PostPosted: Mon Nov 02, 2020 6:31 pm
Red is older 74 75 models no dump valve ,green 76 all cars and most trucks with dump valve
