It is currently Sat Jun 20, 2026 2:27 am
 Post subject: Piston rod question
PostPosted: Wed Jul 21, 2004 2:16 pm
Did clean up some old greasy rods from a 225" and discovered that the #1 differs from the others in its lower end, have anyone any good idea why?
Signet '68 4dr, 460k miles and still rollin'
PostPosted: Wed Jul 21, 2004 9:44 pm
It sounds like the engine may have been "patched together" sometime in the past to repair a spun rod bearing.
If you get an engine that has a bad rod knock, shops / mechanics will need to swap-out the crank and bad connecting rod because they are too damaged to recondition. This is not a problem as long as the replacement con rod is the same weight as the others.
PostPosted: Wed Jul 21, 2004 11:18 pm
I have torn down motors that have never been apart that had two slightly different style rods installed with the same part number, but different markings. I have not encountered this with a slant six, but there is a possibility that, as in the ones I've seen, the factory was probably in the midst of changing vendors (my theory) and the assembler just installed the first 8 rods he happened to pull from the bin. :?
I would be more inclined to believe that a single oddball rod would be more suspect as a repair as DD has stated.
D/W
If it ain't broke, fix it!
PostPosted: Thu Jul 22, 2004 6:26 am
Were these rods, all from the same engine? If they were just in a pile, one of them could be from from a cast crank, while the others are from a forged crank. Or the other way around.
PostPosted: Thu Jul 22, 2004 8:02 am
From the very same engine, and no.1 is the one least subjected to what gruesome things ever can happen inside an engine, the flange towards front has non-concvae surfaces at bottom, between the bolthead and mating point, the "back" side looks like all the rest... :?
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 1 guest
