It is currently Sat Jun 20, 2026 4:55 am
 Post subject: swapping engine out
PostPosted: Sat Jul 24, 2004 1:41 pm
Can i swap the enginge out from an automatic scamp on to my manual 62 with out needing a bell house adaptor?
Does any boby need a scamp for parts??-
PostPosted: Sat Jul 24, 2004 2:20 pm
Car Model: '23 T-bucket
First, what year is the Scamp?....Where is it located?
Roger
PostPosted: Sat Jul 24, 2004 4:28 pm
The size of the flange on the end of the crank, got larger in 1968. To use a engine 1968 or later in a 1962 car/trans will require a flywheel from a 68 or later engine. Also the hole in the end of the crank, may not be finished for a pilot bearing, however there is a special pilot bearing available. You can use the 62 bellhousing, and clutch.
Another solution, is to take the 62 flywheel to a machine shop, and have the center hole opened up to fit the late crank.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 7 guests
