It is currently Fri Jun 12, 2026 10:18 am
 Post subject: Fuel Gauge Problems
PostPosted: Sat Jul 24, 2004 1:56 pm
My fuel gauge is inconsistent, but always fuller than the level it should be on. I've been told it's a bad ground. Where can I find this ground to check? The problem started after I had the cluster out. What could I have done to make it do this?
Thakns
AIM-DusterDude1973
 Post subject: Ivr
PostPosted: Sat Jul 24, 2004 4:59 pm
Never mind. Just make sure that the idiots at the parts store give you the right voltage limiter....errr. Does anyone have a part number on what the limiter should be. My old one makes the fuel gauge work, but the new one didn't make it work right.
AIM-DusterDude1973
