It is currently Tue May 19, 2026 7:37 pm
 Post subject: about a/c....
PostPosted: Wed Aug 04, 2004 10:06 pm
i have a 68 dodge dart without a/c, i was wondering if its possible to put it in a dart of that vintage? can one be pulled off a later model from a junk yard and put into mine? possible? modifications?
PostPosted: Thu Aug 05, 2004 5:23 am
Contributor
Unless you have a world of patience and are concerned about a pure stock look, forget trying to put a factory A/C unit in your Dart. The aftermarket units are relatively easy to install and much simpler than stock.
PostPosted: Thu Aug 05, 2004 11:43 am
where I can find aftermarket "easy-to-install" A/C units?
thanx
PostPosted: Thu Aug 05, 2004 6:09 pm
Contributor
I said "relatively easy". No one makes a complete kit for early A-bodies, but I'm told someone now makes them for the later A's.
I installed a Vintage Air unit in my '64 and if you go to the articles section, you can see what I had to do to make it fit.
Users browsing this forum: Amazon [Bot], Google [Bot] and 12 guests
