It is currently Fri Apr 17, 2026 4:08 am
PostPosted: Tue Apr 14, 2026 8:26 am
Howdy folks. I'm finally doing a disc brake conversion on my Valiant wagon, using the later Mopar sliding calipers on 11.75" rotors. This means I'll need LBP wheels of at least 15" diameter. I'm trying to do this on the cheap, so I'm hoping someone has an old set of steelies they don't need anymore. Even a pair would help if you don't have a set of 4.
Escape Velocity Racing
PostPosted: Tue Apr 14, 2026 9:05 am
Whadda 'bout some ford explorer/ ranger or other 5 Bolt Ford RWD wheels? They can be found in FE or AL and will fit the LBP in Ø14", 15", 16" I do not have any, but I am sure you can pick up something from your local FBM or CL or wrecking yard.
You might need to enlarge the center hub bore a skosh with those choices, but it is easy to do.
