It is currently Thu Nov 26, 2026 3:41 pm
PostPosted: Tue Nov 24, 2026 12:35 pm
My car runs great. No problems as far as performance goes. It generally runs in the 12.80-12.90 range with a best of 12.70@104.7 mph. My question is for a future engine refresh, which I have no Idea when I will do. It is hard to pull apart a perfectly good running engine just for fun. But when I do I want to have all the parts on the shelf to do everything.
My question is regarding a camshaft upgrade. Current camshaft is a Oregon regrind with the following specs:
Intake----.571 lift---267 @.050 duration
Exhaust--.550 lift---262 @.050 duration
It has 106 degree lobe separation, Intake C/L 102 Degree, installed at 99 degrees, 52 1/2 deg. overlap @.050
With valve lash at .024 it only has @160# cranking compression. Tried the valves up to .032 and it really didn't make much difference. This engine is a 11.5 to 1 static comp. ratio.
It appears that it is bleeding off a lot of compression?? So if I were to use the same grind cam and increased the LSA would that increase the cranking compression? Or is there something else you would try if it was yours to squeeze out a couple more horsepower? Again this is just a "what if" type thing now. Give me your thoughts. Thanks
I do have a new set of Weisco 3.504" pistons (currently 3.484") and I always wanted to cut about 10# of counterweights off of a crankshaft and try that. Just dreaming out loud :D :D
PostPosted: Wed Nov 25, 2026 7:44 am
Sounds like a lawn mower cam to me
It least that is what my "Fans" call my cam
PostPosted: Wed Nov 25, 2026 4:56 pm
That's true! But at least we are still racin Stan! :mrgreen:
PostPosted: Wed Nov 25, 2026 6:10 pm
It's over .550" lift. It's good. :mrgreen:
PostPosted: Thu Nov 26, 2026 7:12 am
Where is SlantZilla, and what have you done with his Body??????????????
PostPosted: Thu Nov 26, 2026 7:36 am
Stan I think he is getting soft in his old age! :D :D There is always the possibility that when he typed .550 he meant .750 !!
PostPosted: Thu Nov 26, 2026 7:43 am
:mrgreen:
The rule is less then .550" lift belongs in a lawnmower.
PostPosted: Thu Nov 26, 2026 11:39 am
If I were to use the same grind cam and increased the LSA would that increase the cranking compression?
I have been doing more research and found that this statement is almost surely false. Overlap has very little to do with cranking compression. And it is almost all related to the Intake valve closing point. So for 2 equal engines, one with a LSA of 112 and one with 106, the one with 106 LSA will have more compression. Just the opposite of my thinking.
