It is currently Mon Dec 29, 2025 9:17 am
 Post subject: Cold compression test???
PostPosted: Sat Sep 18, 2004 5:41 pm
Does anyone how difference there would/should be between a coldcranking compression test and hot cranking compression test?
Thanks
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
PostPosted: Sun Sep 19, 2004 12:12 pm
Cold test might be less consistent between cylinders and read lower than a hot test. No oil on the cyl walls can make the seal worse unless they rings/cyl finish is perfect.
PostPosted: Thu Sep 23, 2004 10:12 pm
hot means operating temp of the motor (its been running for 10 or more minutes) cold is room temp. be careful doing a hot because the motor wants to run and ITS HOT
anything worth doing is worth re-doing, again and again and again...........
Users browsing this forum: Ahrefs [Bot] and 3 guests
