It is currently Mon Dec 29, 2025 6:57 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Fri Sep 24, 2004 10:46 am
For a plenum the Weber to SU adapter will work perfectly. Each pair if cylinders and pair of barrels has a common area between the Venturis and the runners with the downdraft 2 bbl adapters stuck to the SU flange.
And if you look at the SU intake there's a balance tube between the three Plenums.
"When applied at precisely the right time, Ignorance is a powerful tool, usually even surpassing knowledge" E.J. "Michigan Madman" Potter.
PostPosted: Fri Sep 24, 2004 11:03 am
A DFAV has the same baseplate as the DGV. It's just got the throttle linkage on the other side.
My truck is a Frankenstein creation
Built from the dead carcasses of others
And brought BACK TO LIFE!
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Mike Andreas and 3 guests
