It is currently Wed Jun 10, 2026 2:33 pm
 Post subject: Need a Distrubutor
PostPosted: Mon Oct 04, 2004 11:20 pm
im trying to find a distributor and electronic ignition so i can hook it up to a MSD box, but i cant find one.
do you guys have a good recomendation where to buy?
http://www.hardymotorcycles.com
PostPosted: Tue Oct 05, 2004 1:13 am
They are pretty common in junkyards.
Its a parts store item as well. Ask for one from a 1973 duster so you get one with a magnetic pickup in it.
MSD boxes will work with points as well but I would still rather use a mangetic pickup for increased reliability.
PostPosted: Tue Oct 05, 2004 4:08 am
Thanks for the input.. thats one more for the salvage yard list. :lol:
PostPosted: Tue Oct 05, 2004 2:28 pm
Btw, what do you mean "and electronic ignition" ? When using an MSD box you don't use the stock EI module, just distributor to msd box to coil to cap to plugs.
I'd get an msd coil as well so you don't have to use a ballast resistor.
PostPosted: Tue Oct 05, 2004 2:59 pm
You can also get remann'd electronic dists at most any parts store. Mine was ~$40 at NAPA. (About 2 years ago)
-S/6
PostPosted: Wed Oct 06, 2004 11:11 pm
talked to MSD like a week ago and im getting wire, coil and box w/rev limiter from them.
and im making EVERYTHING from scratch, so there is no wiring harness or ballast or ANYTHING to go from.
this is my first /6 and i just needed to know what distrib to buy.
 Post subject: As you wish
PostPosted: Thu Oct 07, 2004 8:47 am
You will want the standard electronic distributor. It has mechanical advance and a vacuum advance pod. They where used in slant sixes from 1973-1980. After 1977, it's possible to find a lean burn slant six, which is wrong for your needs.
The article on lean burn delete would help you out a little, but I can't find the link to it. Until I do, here is a post with excellent pics of the item you want and information about performance advance curve adjustments.
http://www.slantsix.org/forum/viewtopic ... istributor
1980 Aspen 225 super six
 Post subject: More links
PostPosted: Thu Oct 07, 2004 8:57 am
Here is the link to the article:
[url]http://www.slantsix.org/articles/leanburn-article_files/leanburn-article.
htm[/url]
It should have pictures and general info that may clear up the water some.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 3 guests
