It is currently Tue Jan 06, 2026 4:40 am
 Post subject: Cam degreeing
PostPosted: Mon Oct 18, 2004 4:58 pm
How can you tell if your cam is not degreed properly? I know if it is real bad, your car won't start. Mine runs good, but I was curious if there is a way to check this without removing the timing cover.
I was thinking along the lines of removing the valve cover and seeing what valves are open when the timing mark is lined up.
PostPosted: Mon Oct 18, 2004 8:26 pm
If it in early the motor will have lots of low end and run out of steam around 4000 rpm.
If it's inm late it will be a real pig down low, and take off around 3500.
Abnormally high cranking compression is kind of a tell tale of early cam installation, low compression would be a late cam.
PostPosted: Mon Oct 18, 2004 11:19 pm
It is pretty easy to check to see if the overlap event is centered over TDCE
See this post for more info:
http://www.slantsix.org/forum/viewtopic ... rlap#43902
Or this link:
http://www.hotrodder.com/kwkride/degree.html
 Post subject: Degreeing a stock cam
PostPosted: Thu Oct 21, 2004 6:26 am
I was told by ex-mechanic neighbor that advancing my stock cam in my 73 valiant by 4 degrees would make a world of difference in performance, is this true?
PostPosted: Thu Oct 21, 2004 10:17 am
You can feel 4 degrees of cam advance in the form of better "off-idle" and low speed "pull".
This is based on using a new timing chain set and knowing that the cam is already set "straight-up" (no advance / retard) and setting it 4 degrees advanced from that position.
Some people just advance the cam 4 degrees with a 4 degree bushing, without knowing where the cam position is to start, that is not a good practice.
Degree the cam, move it the needed amount to set it where you want it.
Users browsing this forum: curmudgeon, Google [Bot] and 2 guests
