It is currently Wed May 27, 2026 4:02 pm
 Post subject: Oil Pan Swapability
PostPosted: Sat Nov 13, 2004 10:50 am
will a 67 b-body slant six oil pan fit a 73 a-body?
 Post subject: Re: Oil Pan Swapability
PostPosted: Sat Nov 13, 2004 11:20 am
Will a 67 B-body slant six oil pan fit a 73 A-body?
Good question, it is really close to fitting but the rear of the sump comes real close to the center link when you turn to "full lock".
I have measured this all out but never actually done the swap, I would like to use the B-Body pan in an A-body because it has a larger sump.
Here is a photo of some common SL6 oil pans, the B-body pan is at the lower left corner, your 73 A-body should have the "087" pan at the lower right corner. Look at how much shorter the rear of the sump is to the back edge of the pan.
If you do this swap please let me know if it clears.
PostPosted: Sat Nov 13, 2004 12:20 pm
sorry, i couldnt get signed in earlier. weve got a 67 belvedere II sedan in the back yard that has 66000 miles on it. since the motor in my 73 dart is getting a little tired, it would be real cheap to just swap motors and i was curious about the oil pan.
this swap might be a good ways down the line but i might try and see if the oil pan will work on my dart.
thanks
