It is currently Sun Dec 28, 2025 1:07 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Tue Dec 28, 2004 10:47 am
Wow!
That looks nice!
One thing that I did was to "tack-weld" the throttle shaft to the bell crank.
As you know - the Offy linkage uses two small set screws (and an expanding pin that you are supposed to install by drilling a hole).
http://dk.favorofareply.com/other/dart/ ... rt_017.jpg
I'm leery of drilling anything that already has such a small diameter (i.e. - the throttle shaft). So what I did was I went to the folks that installed my exhaust, and for FREE they used a mig (or tig?) welder and put a little "tack" to hold the bell crank to the throttle shaft.
The only caveat would be to make sure you have your throttle set up the way you want it - since this is fairly permanent!
One other thing that I did was to install a secondary throttle return spring - both for safety, and also to make sure that any slack in the linkage does not prevent the throttles from closing all the way.
I put the spring on the throttle arm of the "back" carburator - and just hooked it to the threaded hole in the head (between the last two valve cover bolts). I have BBSs - so you might have to do it in a different way.
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
PostPosted: Tue Dec 28, 2004 10:51 am
Another "clean" way to achieve the safety benefit of redundant throttle return springs: Use the Carter BBS specifically for the 1974 Dodge D100 or D150 with the 225 engine. It has a built-in throttle return spring.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
