It is currently Sat Jun 13, 2026 3:34 pm
PostPosted: Thu Feb 10, 2005 12:17 pm
I have a 63 dart wagon 170. it didn't come with reverse lites and I would like to install a pair of original ones. My question is two part:
Originally, when the cars had them, did the quarter plate where they are installed (beneath the tailight) have a round indentation in the metal to accomodate the housing? Obviously, my quarter panels have none because it didn't come with any...so I'm wondering how easily I can install them. Simply drilling a hole may not work, if the metal had a slight flattened area.
Secondly, how would I wire the reverse light switch up to the pushbutton and into the harness, then run the wires back?
Advice? expertise?
Thanks.
PostPosted: Thu Feb 10, 2005 9:26 pm
The FSM shows them mounted barely above the bumper and below
the body line that runs across the tail gate. Cannot tell if there are
dimples there - but I would guess the body contour would be on the
back of the reverse light housings.
The reverse light switch is about the size of a quarter and is mounted to
the bottom of the push button unit if the car is automatic.
 Post subject: 63 wagon
PostPosted: Fri Feb 11, 2005 4:53 am
You have 2 wagons? cool, the kit should have a solenoid/switch that is activated when you car is placed in reverse, as for mounting the 62 valiants I've seen had a small dimple(flat spot) on the rear where the lights go. Also did you check the touchy article on rebuilding your heater switch? replace the highligheted touchy 1 with touchy2 & it will show you the rest of the article.
PostPosted: Fri Feb 11, 2005 9:59 am
Where's that touchy article?
PostPosted: Fri Feb 11, 2005 10:30 am
The '63 Dart wagon backup light accessory package would've come with a template for cutting the necessary holes. Perhaps someone who has a '63-'64 Dart wagon with backup lights can make you a template out of the cardboard backer plate from a pad of paper.
 Post subject: touchy article
PostPosted: Fri Feb 11, 2005 6:06 pm
http://www.1962to1965mopar.ornocar.com/ ... ouchy1.jpg
http://www.1962to1965mopar.ornocar.com/ ... ouchy2.jpgtry these
PostPosted: Sat Feb 12, 2005 4:09 pm
Thanks, good articles!
