It is currently Tue May 26, 2026 5:03 pm
 Post subject: 2b to 1b adapter?
PostPosted: Mon Feb 21, 2005 4:02 pm
do they make an adapter to go from a 2 barrel carb to a 1 barrel?
PostPosted: Mon Feb 21, 2005 5:04 pm
Someone must.
One of these days I'll make a batch on the CNC at work. Who's got a good pattern?
PostPosted: Mon Feb 21, 2005 5:28 pm
Would it not be possible to take the adapter for a 1bbl to 2 bbl and flip it over? I am going back to a one barrel until I can find time to put my super manifold on. I didn't notice any significant change with the adapter and bbd carb. A Hope it gets better with the super setup intake.
PostPosted: Mon Feb 21, 2005 5:37 pm
a question on what u have said. Is it possible to take a 1bbl manifold and use a 2bbl carb. maybe a dumb question but i havent experienced it yet.
PostPosted: Mon Feb 21, 2005 5:51 pm
Dusten, sure, its been done before. Check out www.prolinefuel.com he has the 1 to 2 bbl adapter. I think its availible from your typical auto store as well.
You can flip the same adapter over if you want to go the other direction.
Hoosier I bet you will feel a little difference when using a true supersix intake because the 1 barrel manifold is probably restricting flow of the bigger carb.
PostPosted: Mon Feb 21, 2005 5:52 pm
...why go to all that trouble when two-barrel intakes are readily available? It won't flow worth a crap.
D/W
If it ain't broke, fix it!
PostPosted: Tue Feb 22, 2005 5:01 am
i used the proline adapter to put a holley 5200 on my 1bbl intake. noticeable performance increase and mileage went from 13mpg to 19 mpg. as far as i'm concerned flow is fine and i couldn't be more pleased with the results and it only took about a half hour.
my 2 cents
73 swinger holley 5200, 2 1/4" exhaust .030 over new pistons , cam, .010 under crank. stock everything else. 1/4 mile about a week. 0-60 around 15 sec.
PostPosted: Thu Feb 24, 2005 10:02 am
Unfortunately, ProLine Fuel is not doing business at this time. When/If he does start doing business again, I would highly recommend him. Chris from ProLine Fuel is a great guy to do business with.
'78 Volare 225
'67 Charger 318
