It is currently Wed Jun 10, 2026 8:59 am
PostPosted: Wed Feb 23, 2005 11:49 am
I found a suntune tach at a swap meet. I went to the sunpro site and found info on installing the tach. All the wires are thier, but the difference in the wires are that I have a green wire and they have a white wire. Would these two wires be for the same hook-up?
Also I plan on doing the Hei swap and was wondering if the tach would need to change from being hooked up to the coil to something else?
Thanks!
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Wed Feb 23, 2005 5:36 pm
Green goes to your coil (negative). The white wire is for illumination, I sauldered that to the light switch under the dash.
PostPosted: Wed Feb 23, 2005 8:03 pm
I don't have the white wire. I have a green one. Is the green one for the lights?
PostPosted: Wed Feb 23, 2005 10:39 pm
Is it an illuminated tach? What color wires are coming out the back of it? Green should go to negative hook-up on your coil. As for the HEI swap im not sure :? ... maybe someone else can help?
PostPosted: Fri Feb 25, 2005 11:25 am
Red, Black, Blue, Green. Those are the cpolors of wires I have.
PostPosted: Fri Feb 25, 2005 3:37 pm
Red-power
Black-ground
Blue-lights
Green-coil
The Green wire would still go to the negative coil terminal on HEI.
PostPosted: Fri Feb 25, 2005 8:13 pm
OK! Thanks!
