It is currently Sat Dec 27, 2025 9:34 am
PostPosted: Thu Feb 24, 2005 11:45 am
Car Model: 1962 Lancer 770
I'd go with 2 1920
As always, someone just HAS to say "do the opposite!" =)
Whichever breed you prefer, those are the two common choices. I believe that of the folks on the board that I've seen with this setup, ricki has 1920s, 63Dart has carters (see above). They're both happy ;-)
MJ
PostPosted: Thu Feb 24, 2005 11:56 am
Thanks Argentina for the compliment on the motor. Yes, at first I fretted a little bit about whether I was going to get enough carburation - but then I did some research.
Given a 5,000 RPM redline - a little porting, and 232 CI displacement, I still only need 318 CFM of air.
The BBSs (and 1920s) each flow somewhere around 180 - so I'm OK as long as I don't need/want to go above about 5600 RPM.
I've driven this (with its rebuild) for a week now - and the torque is amazing. Freeway passing from 60 to 80 MPH is effortless and does not even require that I kick it down into 2nd.
:D
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
PostPosted: Thu Feb 24, 2005 12:00 pm
Your new setup is cool looking, but we miss Amos in your sig :lol:
PostPosted: Thu Feb 24, 2005 1:48 pm
MJ
ha
you know me, I couldn't help it. :lol:
Argentina's darts GT (only ones wich had this setup directly from factory) had a local reengineering of 1920, called 1922. Accel pump is not diaph, it's a piston with a rubber sleeve that works way better than 1920's accel pump, and metering block is smaller. Those carbs rocks, but I guess that if I'm in trouble down here to get those, i can only imagine how much of a pain in the ass would be up there. float is center hung and fuel inlet is on the bowl's cover.
I suggested 1920 cuz it has somewhat a more modern desing that BBS.
Juan Ignacio Caino
Users browsing this forum: Ahrefs [Bot] and 14 guests
