It is currently Wed May 20, 2026 6:49 am
 Post subject: blown head gasket
PostPosted: Sat Feb 26, 2005 6:43 am
my slant is blowing water out the exhaust pipe....why do I not see water in the oil or oil in the water....also compression 120 t0 130 all cylinders...I'll be taking the head off tomorrow....anything in particular I should be looking for....thanks...vic
PostPosted: Sat Feb 26, 2005 7:55 am
Same situation I was in last summer. Look at the block to see if and water jackets are blown out, you may just have a blow out inbetwen cylinders. There was a hole where mine blew in a water jacket. It put a hole through the top of the block, through the gasket,through the head...not good. It's a 15$ fix though :)
 Post subject: vic vickery
PostPosted: Sun Feb 27, 2005 12:39 pm
I'm assuming you just mean replace the head gasket....vic
Users browsing this forum: ceej, Google [Bot] and 12 guests
