It is currently Fri May 15, 2026 7:40 pm
 Post subject: valve question????
PostPosted: Sun Feb 13, 2005 6:58 am
How big of a valve (exsaust and intake) can be put in a 1971 225 head,thanks,,,speedfreak.
PostPosted: Sat Feb 26, 2005 7:30 am
WOW,,,no one????will smallblock valves from a mopar fit???help please,thanks,,,speedfreak.
PostPosted: Sat Feb 26, 2005 10:20 am
It's been covered many times throughout the forum. Do a search on 'valve size' and you'll get about 12 pages.
It's a Slant thing. Even I don't understand.
1974 Duster, EFI /6 soon to be turbo...
Get that Monkay! Get that nasty thing!!
PostPosted: Sun Feb 27, 2005 6:35 am
well I tried valve size and wording it deferent ways and it told me no matches,this happened on other search topics with the same results,whats up with that?
PostPosted: Sun Feb 27, 2005 12:11 pm
Try big valves, and ford 300 valves... :)
PostPosted: Sun Feb 27, 2005 6:18 pm
Try searching under "over sized valves" - Good Luck!
PostPosted: Sun Feb 27, 2005 6:46 pm
http://www.slantsix.org/forum/viewtopic ... valve+size
These were found using a search criteria of 'valve size' in the message field.
PostPosted: Sun Feb 27, 2005 7:39 pm
I put 1.72 and 1.50 SBC valves in my head. It is a definite advantage to Sweep the chambers around the valves for flow. The bowls need to be enlarged to match the valves.
PostPosted: Mon Feb 28, 2005 6:32 am
Everyone,thanks allot,just what I was looking for,i've played around with 318,340,360,but this is the first time for a 225 or any 6cyl,its all new to me,thanks again,,,speedfreak.
Users browsing this forum: Bing [Bot], Google [Bot] and 31 guests
