It is currently Thu Jun 11, 2026 6:34 pm
 Post subject: 2 bbl problems
PostPosted: Fri Mar 25, 2005 6:05 am
I have a 74 sattelite 41000 org. miles 318 2bbl the car has a random bog on heavy acceleration. Seems to hapen after the tranny shifts from 1 to 2 or 2 to 3. I have tried the fuel filter and replaced it but this still hapens. any sugestions?
PostPosted: Fri Mar 25, 2005 6:04 pm
Check the following:
Accelerator pump
Metering rods (Are they stuck?) Carter
Power valve (Blown?) Holley
OSAC valve removed? (If not, do so)
Timing set wrong
Blown Vacum pod.
running too lean
Vacum leak.
Incorrect float level (not sure, help me out here.)
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri Mar 25, 2005 11:15 pm
well of your list I can rule out
Timing set wrong-its the same as when I got it.
Blown Vacum pod.-advance is disconected
running too lean-on the bog I have been told I get some dark smoke not a lot though
Vacum leak.-nothing showing on my vaccume gauge
Incorrect float level (not sure, help me out here.)-wouldnt this cause a constant problem?
PostPosted: Sat Mar 26, 2005 9:18 am
Jeb had mentioned the accelerator pump.
Have you fiddled with it to give you a bigger shot of gas?
This has worked for me in the past.I have also gone up a couple sizes on the main jet with good results. :wink:
JZ
PostPosted: Sat Mar 26, 2005 9:21 am
What knida carb you're using? carter? holley?
if holley, you have center hung float or side hung? high float level can be giving you random failures especially "after shifting" as you mention (when the car "moves" up or down the front end and the carb "shakes" up and down it can spurt some gas down the barrels)
also your bog can come from unhooked vac pod, when the tranny shifts and revs goes down your advance curve may be backing off too much... causing your timing to go on the retarded side (remember that less timing creates a "richer" condition) and producing the bog unitl your engine revs up again.
I would certainly rule out "running too lean" if you're on a holley :)
that's my 2 cents
Juan Ignacio Caino
PostPosted: Sun Mar 27, 2005 3:45 pm
Try hooking back up your vacum advance, that may be your problem right there.l
82 D150-225/727
