It is currently Fri May 22, 2026 9:26 am
PostPosted: Sat Mar 26, 2005 5:21 pm
Have a 62 Lancer GT. 225 salnt six Ballast resistor appears to be on firewall. Instructions say to connect red wire to ignition side of ballast resistor. Red wire supplied with unit is only 12 inches long. I need about 4 feet to get to the firewall. Do I need to splice into it and make it longer? If so why dont they come with a longer line. Its easier to cutt wire than to add to it...
PostPosted: Sat Mar 26, 2005 5:39 pm
I guess they're assuming you'll mount the module near the ballast resistor (or the ballast resistor near the module).
Yet another reason to use HEI instead of Pertronix... :-)
PostPosted: Sat Mar 26, 2005 6:26 pm
Isn't the ignition side of the ballast resistor just the + coil wire? If I understand those directions correctly that should be right. Don't need a very long wire for that. Use an ohmeter to check for zero (< 1 Ohm) between coil + wire and ballast plug (unplug both ends).
PostPosted: Sat Mar 26, 2005 6:42 pm
Dart 270.... That is kinda what I was wondering. Seems odd to have to go to the firewall and tap into the ballast resistor . I would think the + coil side too but I was not sure...Anyone else have an idea?
 Post subject: pertronix
PostPosted: Sat Mar 26, 2005 8:07 pm
Sorry, you will have to splice the red wire-- did my 62 valiant the same way, the black wire goes to the coil & the red wire goes to ballast. Get some heat shrink & splice in the wire --also I got a splitter from radio shack so I would have two male terminals at the resistor. The unit works great-- anyhow on my car it smoothed out the idle & seemed to start a little better. 8)
PostPosted: Sat Mar 26, 2005 10:21 pm
Red wire to + side of coil
Black to - side of coil
Another great product being bagged on,probably without ever even trying it. :?
 Post subject: petronix
PostPosted: Sun Mar 27, 2005 4:33 am
red wire goes to ballast on factory equiped cars- if your are using the pertronix II maybe you can bypass it, the instructions do not recommend by-passing the ballast resistor, been running on my car for 2 years that way.
PostPosted: Sun Mar 27, 2005 5:12 am
I would think you can connect to the coil.
Or does it matter if it is a factory, or aftermarket wire? :wink:
PostPosted: Sun Mar 27, 2005 8:04 am
VDART...How do you know what side of the ballast resistor to hook it to? There are 2 terminals and they are not marked at all. It is mounted vertically on the firewall. Top or bottom terminal????
PostPosted: Sun Mar 27, 2005 8:35 am
http://members.cox.net/69dartcv/IMG_6916.JPG, Here is the connection on my 62-- 170, someday I'll swap in the 225, sure like the pushbutton tranny!!!
It is the red wire on the top-- when I swap in the 225 I'll clean up the engine compartment!!!!!
 Post subject: Pertronix
PostPosted: Sun Mar 27, 2005 9:25 am
Yea, The directions say to install it one way. I called them directly and asked the question. They said that you can hook it to the + and - side of the coil with no problems. Been running 2 of them that way for over 5 years now on a /6 and a 383 with no problems. Go for it!!
PostPosted: Sun Mar 27, 2005 11:51 am
Dont know how more clear we can be on this.
Red to + side of coil
Just like 69 a100 I have been running the same pertronix on my car for close to 3yrs (hooked up this way)and have naver had to touch it since.
Keep in mind once you do hook it up that the gap has to be spot on or it will not run.They give you a plastic feeler gauge for this.
JZ
PostPosted: Sun Mar 27, 2005 5:56 pm
I will do it the simple way. Directly to the correct coil terminals. I will hopefully try to start it this week for the first time. Wish me luck
PostPosted: Mon Mar 28, 2005 12:33 am
i read on the instructions that you take the ballist wires and splice them together
then red to +
black to -
right?
70 Plymouth Valiant 4dr
PostPosted: Mon Mar 28, 2005 7:02 am
Leave the ballast in if you are running stock coil, or bypass the ballast if you are running aftermarket internal resistance coil.
72 Scamp 225 /6, auto, radio delete, alum super six, cold air duct, pertronix ignitor II and flame thrower, 3.23 rear, 2.25" free flow exhaust
Users browsing this forum: Bing [Bot], Google [Bot] and 22 guests
