It is currently Wed May 13, 2026 2:32 pm
 Post subject: Dutra duals fit
PostPosted: Thu Mar 24, 2005 9:13 am
I just got my front Dutra dual and I noticed a clearance problem on the very front part of the front manifold. On the bottom below the first mounting hole there is a tab on my aluminum engine that interfers with it. Is it easier to grind the aluminum hump off the engine or modify the flange on the duals?
PostPosted: Thu Mar 24, 2005 12:36 pm
Dutra front castings are a lot more common than aluminum 225s :-)
 Post subject: Dutra duels
PostPosted: Thu Mar 24, 2005 9:22 pm
I just last week put them on my 62 signet with the aluminum block,I also had same issue,two minutes with dremel,and block was clearenced,They work very well with my two one barrels,Mark
    PostPosted: Fri Mar 25, 2005 10:38 am
    I had a similar problem and I just ground off some material from the manifold with my angle grinder. I think it is simpler to grind the manifold because it is smaller and easier to handle than the block.
    PostPosted: Sun Mar 27, 2005 3:51 pm
    I had to grind mine to fit the head also. My Dutra must have been from an off batch because I had to have it surface ground to even up all of the sealing surfaces to where it wouldn't leak. Cutting the excess from the outlet flange at angles made it easier to get a socket extention in to tighten the stud nuts and took off about a 1/4 pound of uneeded iron. It took me three or four tries to get a good seal and no leaks but I've been happy with it and the better engine power ever since. One trick that I did come up with was to cut the manifold gasket in half between the front and rear sections so that I could take off just the Dutra and leave the rear section in place undisturbed.
    "Former Owner" of '65 Barracuda, 225, Auto, MP 2bbl intake, MP cam, Dutra Duals. Presently Moparless.
     Post subject: One Question.
    PostPosted: Mon Mar 28, 2005 10:24 am
    Where I can buy Dutra Dual exhaust?
    Mopar Muscle is well defend by Slant Six!
    Valiant Duster 1971
    PostPosted: Mon Mar 28, 2005 10:44 am
    Here, directly from Dutra!
     Post subject: Wow!
    PostPosted: Mon Mar 28, 2005 9:41 pm
    Excellent, but looks like I will need to save a LOT of money to buy them, basically for shipping cost to me.
    Valiant Duster 1971
