It is currently Mon May 11, 2026 9:46 pm
 Post subject: My timing isn't right
PostPosted: Mon Apr 04, 2005 11:55 am
I have a 76 and the most I can retard the timing is 12BTDC.. The adjuster screw simply won't allow thew distrib to turn any farther. What can I do?
PostPosted: Mon Apr 04, 2005 12:25 pm
Remove the distributor, and reposition the plate on the bottom.
PostPosted: Mon Apr 04, 2005 12:26 pm
12 BTDC is quite a bit ...
 Post subject: What he said
PostPosted: Mon Apr 04, 2005 1:11 pm
There is another adjusting bolt, but you can't really see without removing the distributor. Once you know where it is, it can still be pretty tricky to get at without removing the distributor.
I always turn the crank around to top dead center on the #1 stroke before I pull the distributor.(remove the cap and check that the rotor is pointing at the #1 spark plug wire) This way I am alway very close to correct when putting it back in. Be aware that the rotor will turn counter clockwise (about a 1/4 turn) as you remove the distributor, so you'll need to install it starting in about the same location so the gears will mesh clockwise back to the correct position.
Good luck, it's not nearly as difficult the second time, or the third or fourth, 5, 6, 7 :roll: That's what happens when you start experimenting with distributor recurving. :wink:
1980 Aspen 225 super six
PostPosted: Mon Apr 04, 2005 2:30 pm
Another easier thing you can do is pull the distributor out and move the shaft one gear tooth over, then reinstall it and see where youre at. It's possible it was installed with the shaft indexed improperly.
