It is currently Thu Jan 01, 2026 8:14 pm
 Post subject: timing chain
PostPosted: Sat Jul 02, 2005 9:09 pm
well, i got all the gaskets, spent the day tearing down the car. when i got to the " damper", i find that i need a special tool #c-3732a to take it off. where can i get one or is there another way to take it off? thanks!
PostPosted: Sat Jul 02, 2005 11:58 pm
You just need to check with your local parts store in the tool aisle, or Harbor Freight has a pulley puller set (the kind that uses bolts not the type that uses the "claws"). It should be relatively inexpensive.
PostPosted: Sun Jul 03, 2005 6:27 am
Autozone will probably rent you one cheap. IIRC, they also have them in their tool aisle for about $15 or so. :shock:
 Post subject: damper
PostPosted: Sun Jul 03, 2005 8:32 am
i have a set of gear pullers. is that what i need? thanks!
PostPosted: Sun Jul 03, 2005 8:37 am
the manual says to block up the crank so that there is no movement. how is that done? thanks, again!
 Post subject: Re: damper
PostPosted: Sun Jul 03, 2005 10:22 am
NO!, you will destroy your damper with a "gear puller".
You need a harmonic balancer puller available at most any auto parts place, hardware store, and farm&fleet type stores. It has bolts that thread into the holes in the hub of the damper.
Like this.... http://www.lislecorp.com/tool_detail.cfm?detail=813
 Post subject: puller
PostPosted: Sun Jul 03, 2005 11:44 am
thanks, Craig, i think i'll run over to "Sears" and see if they have one. i've got a few other vintage automobiles i will probably need one for anyway.
 Post subject: Feeling Lucky....
PostPosted: Sun Jul 03, 2005 2:24 pm
Just for the hell of it, have you tried just pulling on it with your hands...............
Worked on my toyota pickup...........
As I was underneath the front deciding if I had to remove the radiator to have enough room to get a gear puller over the pulley, I just decided to yank it to see if it would move................. I pulled it right off, big (pleasant) surprise....
 Post subject: timing gear
PostPosted: Sun Jul 03, 2005 3:11 pm
well, i got the puller. problem is the hamonis balancer and my a/c pulley are bolted together from the inside out. are they suppose to be one unit?i tried pulling them off together and ..no way. also, how am i suppose to stop the crank from spinning? thanks!
 Post subject: got it!
PostPosted: Sun Jul 03, 2005 5:48 pm
for those of you who read this and didn't know. the two pulleys are bolted together from the inside and are one unit. i took a shot at just putting all the plugs back in and it was enough to hold the crank still till it broke loose.
PostPosted: Sun Jul 03, 2005 6:51 pm
So are you saying you got it off? Good job!
PostPosted: Mon Jul 04, 2005 1:36 am
yes, tomorrow i will try to finish putting the chain and gears on, flush, repair, and paint the radiator and if possible loosen the motor mounts and try to change out the oil pan gasket (i've read it's a real pain). i really can't get over how loose the timing chain was! although using a nylon gear was probably the reason why. thanks!
Users browsing this forum: Bing [Bot] and 6 guests
