It is currently Tue Nov 18, 2025 3:02 am
PostPosted: Mon Aug 08, 2005 2:05 am
is it an English Rootes straight six from the humber hawk? I found a humber hawk here in hte UK and in the boot (trunk) there is a hemi head, and in the front under hte bonnet (hood) there is an upright six, looks smaller than a 225, I would guess 2.5 to 3.2 liters based on bore size. the head was definately hemi though and had goofy pushrod arrangement to make it all happen. I know that rootes and crysler had somewhat of an association, with chrysler eventually buying rootes, and making cars in europe that looked a lot like us cars (the rapier which looked a lot like the barracuda)
So, is this the link, the orrigin of the hemi six? thanks
PostPosted: Mon Aug 08, 2005 6:47 am
The Ozzy Hemi six has the manifolds on the same side and the "hemi" chamber has the valves canted "front to back".
It is not a true cross flow head, more like a mix of a hemi combustion chamber and a wedge design.
PostPosted: Mon Aug 08, 2005 9:36 am
No, the Hemi-6 (D-engine) was a clean-sheet design initiated by Chrysler Corp. in the USA, then given over to Chrysler Australia. There was no Rootes (or other UK or European) involvemet or parts sharing.
PostPosted: Mon Aug 08, 2005 1:57 pm
this has single side ports. iill take a photo. is it possible rootes took it for the hawk or are they completely different engines?
PostPosted: Mon Aug 08, 2005 8:03 pm
and what would it cost me to import on of these to canada?
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Mon Aug 08, 2005 8:32 pm
Shipping would be the main thing, but I know of a number of people who've imported Hemi-6s to North America. Conversion mounts are available for pretty much any '63-up A-body.
PostPosted: Tue Aug 09, 2005 1:28 am
You can get a decent hemi six for about $300 aus or so. Will be a healthy running engine. I recently sold a complete valiant with a good 265/ 4 speed/ dual exhaust for $1200 aus.
You want a 265 though if you are going to import one. Larger valves and generally the best of the hemi sixes.
Get a late model one, and you'll get a dual outlet exhaust manifold. You can buy all the usual gear for em, like 4 barrel manifolds, but extractors may be an issue in LHD cars.......
If you go to moparmarket.com and shoot Ozhemi a message, he should be able to point you towards a hemi six in the US. He exports stuff to Aus, and also does some importing the other way.
Regards, Andrew.
PostPosted: Sun Aug 14, 2005 3:36 am
No, the Australian six was a hemi in name only. It came in 215, 235 and 245 cid sizes, with wedge heads and the spark plugs on the side of the head.
Rootes was a British firm and purchase nothing from Chrysler Australia. The engine used in the Super Snipe (the Hawk had a 4) was an ohv hemi with two rocker shafts. The engine was introduced for 1958 having a 3.25" bore and stroke giving 162-cid (2.7-litres) and 105-bhp. In 1959 it was bored out to 3.44" resulting in 181-cid (3.0-litres) with 121-bhp. The engine was last used in 1967 having 129-bhp.
And it was actually not a Rootes engine, but was designed and built by Armstrong-Siddeley. A-S stopped building cars in 1960, after facing a decade of falling sales. Rootes needed a new 6-cylinder engine for the redesigned Super Snipe for 1958 and A-S had extra engine manufacturing capacity. And the extra work helped keep the firm solvent.
Another bonus of A-S falling sales was extra manufacturing capacity. And Rootes took advantage of this by having A-S built the Sunbeam Alpine. Rootes shifted Alpine production to its Ryton plant in the spring of 1962.
Bill
Vancouver, BC
PostPosted: Sun Aug 14, 2005 6:07 pm
Slight correction - our Hemi came in 215, 245, and 265 flavours.
