It is currently Tue Nov 18, 2025 9:16 am
 Post subject: Need to id a 225
PostPosted: Sat Aug 13, 2005 9:09 pm
Need a new rear seal and want to id block be for I start. Got the motor from a wrecker, said it was a 80 or 81. Is there any way of telling the years apart. Thanks
PostPosted: Sat Aug 13, 2005 9:16 pm
All the rear seals should be the same, 1960-86 Slant Six
Look for the ID number stamped into the top of the block, that will tell use what year the engine was assembled.
 Post subject: 225 rear seal
PostPosted: Sat Aug 13, 2005 9:24 pm
There is a listing for two seals one for 80 and down and one for 81 to 86 two diffrent part numbers
PostPosted: Sun Aug 14, 2005 8:19 am
Donno whose catalogue you're looking in. There's a different whole-engine gasket set for '60-'80 vs. '81-up, because the head gasket's different, but the rear main seal is the same.
PostPosted: Sun Aug 14, 2005 2:11 pm
http://i7.photobucket.com/albums/y281/lauchlin/part.jpg
Users browsing this forum: Google [Bot] and 20 guests
