It is currently Sat Nov 14, 2026 7:52 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Fri Aug 19, 2005 10:01 am
It cranks fine, however when the engine fires and overruns the starter it makes a weird clackety grinding sound. Is this normal sound for these?
No.
Got any idea what may be causing this sound?
Faulty overrunning clutch. When it finishes failing, it'll either lock up and lunch the starter, or stop transmitting drive (starter will go "whizzzzzz!" but won't crank engine). If you don't plan on fixing it right away, keep a spare starter and appropriate wrenches in the trunk!
Is some kind of a heat shield in order?
There is a heat shield available for this starter, but because of their permanent-magnet construction, these starters are extremely heat-resistant. I don't think you're likely to have a problem.
PostPosted: Fri Aug 19, 2005 10:49 am
Hmmm.... I took it apart before installation and saw that it has wound fields, not permanent-magnet construction.
I'm more concerned about cooking the lubricating grease in the bearings and gearbox into charcoal.
PostPosted: Fri Aug 19, 2005 10:56 am
Unless your running headers, I wouldn't worry about heat.
PostPosted: Fri Aug 19, 2005 8:34 pm
Steve - you have to be careful, I don't think a sub $100 unit will be a genuine ND, but I could be wrong. New $85 ones are all over ebay.
The site is Partzfinder.com, and the price is $79.99 or $99.99 depending on which you get - see these: early Durango/Dakota style and newer, smaller version (descriptions per Dave Shultz aka BK on MoparStyle). Several people on the MoparStyle forums have these, and haven't had any problems.
Remember not everyone marks the price of everything 200+%, some places sell closer to their cost (i.e. like Walmart). The places on eBay though may be buying the cheapies and marking them up enough, so people think they're the genuine item.
Steve G.
PostPosted: Fri Aug 19, 2005 8:40 pm
There's nothing wrong with the later short-motor type, and they're a little lighter—those, in fact, are the permanent-magnet items. The critical thing is you gotta get one with a nosecone.
That said, I guarantee you the ones on partzfinder are not genuine, they're Chinese copycats. For one thing, Nippondenso doesn't cad-plate their motor frames, but the Chinese do. For another, you do get what you pay for, and you don't get a new genuine starter for 80 or 90 bucks.
