It is currently Sat Jun 13, 2026 3:12 pm
PostPosted: Sat Oct 01, 2005 8:00 pm
I would like to ask Dennis Weaver about post on May 2005:
Replaced sector shaft seal on his car.
Is sector shaft seal same as pitman arm lower seal?
The power steering box at bottom where shaft comes out
and joins to pitman arm is leaking.
after removing pitman arm did you use a cotter pin
puller (curved hook tool) to pull the seal out? or something else.
Thanks,
PostPosted: Sat Oct 01, 2005 9:45 pm
I've never heard anyone call it a pitman arm seal, but yes, that's the one. The shaft the pitman arm goes onto is the sector shaft.
Thanks,
It's been such a long time since I've done that, I forgot what worked best. Any kind of device like that would be a good candidate. I think maybe I used an old (small) screwdriver and just levered it out alongside the shaft.
You're welcome, any time.
D/W
If it ain't broke, fix it!
 Post subject: sector shaft seal
PostPosted: Tue Oct 04, 2005 9:46 am
The great factory tip for removing the sector shaft seal on a PS car (not in the Chiltons), was to remove the retainer, put a bucket under the shaft, then start the car and turn the wheel all the way to the left (maybe right, it's been awhile) and the pressure would blow the seal out.
I tried that trick and it worked great. Alternatively, there's a funny special giant-easyout-like tool for the job, but I don't know where you'd find one.
PostPosted: Tue Oct 04, 2005 10:09 pm
Thanks for the tip.
I will try that.
I think mactools or matco made that tool
i saw it on ebay.
