It is currently Tue Jun 16, 2026 1:54 pm
 Post subject: Angled Head Shaving?
PostPosted: Sun Nov 13, 2005 11:35 am
Found this on an Aussie Mopar site discussing slant six head milling
once we built up a slant and took 200"of the push rod side and nothing off the manifold side(wedge shaped)to put the combustion chambers at a better angle:smoki to the cylinders-went like stink!!
Any thoughts on this? I've heard that detonation control on a higher compression slant is difficult to do, in part because of open chamber design.
-Mac
[/quote]
PostPosted: Mon Nov 14, 2005 7:04 am
This a very old trick. I haven't seen back-to-back comparisons of HP, but it makes some sense to do it.
I have two heads with angle mills - 0.080"/0.180" (intake/plug side) and 0.100"/0.200". They have worked well in street/strip motors for many years.
Meril Bruner has used the 0/0.200" mill and he gave me the idea back in 1991.
PostPosted: Mon Nov 14, 2005 8:38 am
When you do this - do you have to also remachine the head bolt holes and flat bosses?
I would imagine so,
PostPosted: Mon Nov 14, 2005 11:05 am
Most people do. I did not on mine since I only had a 0.100" offset. No head gasket problems in 10 years and many head swaps, UNTIL this summer. Not sure why it happened and will pull the head to investigate. Not a head bolt issue, though.
PostPosted: Thu Nov 17, 2005 4:03 pm
Lou, When you do the .100" / .200" Angle mill, Does that mean that you do .100" off as a regular head cut, then another .100 at the angle after the first cut?
PostPosted: Thu Nov 17, 2005 7:11 pm
Couldn't tell ya. I just told them what I wanted and they did it.
