It is currently Sat Sep 19, 2026 12:36 am
 Post subject: safe bore size
PostPosted: Fri Nov 25, 2005 5:26 pm
what is a good and safe bore 30 over ,,,,,,,125over what?
PostPosted: Sat Nov 26, 2005 2:53 am
0.060" is very safe. 0.100" over is quite common with racers, although some feel the need to sonic check. 0.140" is about the max safe overbore I've heard - good idea to sonic check.
PostPosted: Sat Nov 26, 2005 6:38 am
It depends on what you want to do. On a stock rebuild, +.030 would be fine. For any kind of performance build, the bigger the bore, the better the head will flow. Mine has always been +.065 on my street motor, and that was mandated by the pistons I used. My next rendition will be +.100". +.100" gets you into a bore size that is somewhat easier to get pistons made for. :shock:
PostPosted: Sat Nov 26, 2005 6:57 am
How about 170. Is it safe to bore to 89mm, ~+.100? It´s going to be turbocharged and will see lots of boost. Or should I stay with 88mm bore, ~+.065. The same piston is available in 87mm, 88mm and 89mm.
