It is currently Tue Dec 30, 2025 1:13 am
 Post subject: MP header
PostPosted: Thu Dec 15, 2005 5:37 pm
I was wondering if anyone noticed that Jegs sells the MP header for really cheap compared to other headers. I was wondering for anyone who knows or has the MP header if it will fit the 66 and back Abodies. So far the Cliffords are the only ones that will. I had the opportunity to buy a Hooker supercomp header and a offy 4 barrel intake with a edelbrock carb on it but he wanted to sell them both and wouldnt sell them seperate and wanted 300 bucks for em. The supercomps wont fit pre 67 Abodies otherwise I would have bought em. Also Jegs has 4 or 5 different cams for a slant but they dont give u any info on them at all. Anyway just wanted to see if those MP headers would fit pre 67 a bodies.
thanks
PostPosted: Thu Dec 15, 2005 6:10 pm
Those headers can be "made to fit", but it ain't pretty. If you have a column shifter I wouldn't even try.
PostPosted: Thu Dec 15, 2005 6:41 pm
So basically its either clifford or no header. And i do have a column shift.
Well if clifford didnt want 350 bucks for theirs then i wouldnt mind do much. Are their any other headers out there that anyone knows about?
PostPosted: Thu Dec 15, 2005 8:32 pm
And the answer is........No. :shock:
PostPosted: Fri Dec 16, 2005 4:19 am
I have run 12 second ETs through "Dutra Duals", they are a good compromise, especially if you are working on a "street-strip" type car.
PostPosted: Fri Dec 16, 2005 5:18 am
I have been trying to get a "header" person to build some early "A" slant six headers, both for the 170 and 225. He can copy my Cliffords. Trouble is everytime I get an OK, he gets busy, with other work. If he does the slant headers, they would be "fill in" work.
PostPosted: Fri Dec 16, 2005 6:09 am
Charlie,
What if you could guarantee him a lot of 5+ sets. Would that get his attention?
PostPosted: Fri Dec 16, 2005 7:06 am
I will ask him, but not untill after the first of the year. He works a full time job, and is getting a bunch of year end overtime, so he is not doing any headers until then.
PostPosted: Fri Dec 16, 2005 7:15 am
Is the MP header the 6 into 1? Would it fit my 64 Dart with pushbutton auto? It would be nice to have options.
64 Dart 170 /6
PostPosted: Fri Dec 16, 2005 7:19 am
Just had a phone call, from the guy that makes the headers, and we had a discussion. Main question:
Long tube, similar to the old Clifford, or "shorty style". I will start a new thread, in the "other" forum.
PostPosted: Sun Dec 18, 2005 7:33 pm
Can anyone tell me how big of a pain it would be to fit a Mopar Header into my 1964 Dart?
thanks,
josh
64 Dart 170 /6
PostPosted: Mon Dec 19, 2005 10:38 am
ya Dutra Duals are very good for a street/strip manifold. You could buy the front part and just cut up your current manifold to make the rear, doesnt look like it would take much and save money :P plus ive read that headers were only worth about a tenth in the quarter as said by doug himself who tested dutra duals vs headers.
i myself to save money probably would have gone this route on my 66 mp headers wouldnt fit plus its a colum shift :shock: but i was going to covert to a 4 speed :)
Cuda Progress :D
The dart as it sits now :(
PostPosted: Thu Dec 22, 2005 8:20 am
I bought one of the MP headers for my Demon. It is a 6 into 1 with a 3" collector. Fit well and worked well, but I did have to file most of the mounting holes oval to bet it to bolt up right and not ruin the gaskets in a few days. The bolt hole pattern was off a little bit compared to the ports. After massaging it, I did my usual header gasket trick. I use 2 gaskets and glue them together with Permatex 3H (thick brown stuff in a small bottle with a bruch cap) and then glue both sides so that it sticks to the head and the header. After that, it was fine!
As far as cams go, I ran the .460 lift 268 duration MP cam and it ran GREAT! The car had a single 3" exhasut system all the way out the rear and people always thought it was a 340 car. It had that great rumpy V8 sound at idle and a cool moan cruising. I used a Flowmaster 5" thick SUV muffler and thier 3" universal tailpipe kit to get the mandrel bends up over the axle. I also used a late model head to get rid of the spark plug tubes and ported the bowls.
It all worked out pretty well. I should have kept THAT car instead of the Rampage I kept. Even with all that stuff on it and driving it having fun, the Demon still got about 17 mpg.
A guy out in NC bought it - wondering if it's still around.........
Marc
www.marcmedina.com
PostPosted: Sat Dec 24, 2005 6:29 am
thanks,
josh
Charlie_S and I know someone who put the MP header into a '66 Dart.
He unbolted the motor mounts, raised the motor up with a hoist, bolted on the header, then drop slammed it back into the engine bay. Then he fixed all the crushed pipes. As Charlie_S said, it will go, but it's ugly.
Slant Cecil
Users browsing this forum: Amazon [Bot], Google [Bot] and 1 guest
