It is currently Wed May 27, 2026 9:52 pm
 Post subject: Startup woes
PostPosted: Sun Dec 18, 2005 9:51 pm
My first post, I've read your forum with interest a few times while on a current project truck..
I have an '82 D-150 with an SCC and California emisssions system, just rebuilt the /225 engine and can't get it started. Not being too familiar with the SCC system ( mounted in the air cleaner) -- I replaced the most suspect items: dual pickup coils, ignition coil, starter relay, distributor cap and rotor before finally suspecting the SCC to be the problem. I've checked all related wires using a schematic, all have continuity. I have sufficent fuel too.
I sent the SCC in for a rebuild, yet still have the exact same problem. It has spark while cranking, but the engine just coughs as the ignition switch is released.
Is there a way to test the " run" side of the SCC brain or am I fighting a loosing battle with thsi SCC? Any other suggestions? I read a couple of mentions of installing a standard ignition system.
This truck is in great shape, but I need to fix and sell it, and it has to pass CA emissions. Advice from experienced slanters welcomed!
thanks, lf
PostPosted: Sun Dec 18, 2005 11:02 pm
My mechanic begged to replace the lean burn on my truck ('83). I have to say, it has made things a tad easier to deal with. What I do vaguely remember about the lean burn was possibly getting the two magnetic pickups confused. And while there is no contact with the fins of the reluctor, it occured to me that they might not have the same radius or thickness.
Since you said you rebuilt the engine, have you checked to be certain the distributor is aligned properly? I've had mine 180* off and it sounded like crap when I could get it to run.
And why would you want to sell it?
PostPosted: Mon Dec 19, 2005 6:03 am
How do you get a slant distrubutor 180 off? They don't have a slot they have gears.
PostPosted: Mon Dec 19, 2005 6:44 am
Yeah...which means you can get it ~20° off, ~40° off, ~60° off, ~80° off, ~100° off, ~120° off, ~140° off, ~160° off, ~180° off, ~200° off, ~220° off, ~240° off, ~260° off, ~280° off, ~300° off, ~320° off, ~340° off or just right. Offhand I don't remember how many teeth are on the distributor drive pinion...however many there are, that many minus one is how many incorrect installations can be made.
PostPosted: Mon Dec 19, 2005 6:53 am
Um, I was going to say that the rotor button would only go on one way. If you alighn it with the #1 post and the #1 cylinder on the wronge stoke at TDC, it will be off.
The Old Goat '83 D150 225-2
AKA Ice Titan
PostPosted: Mon Dec 19, 2005 6:54 am
Simple - Disturb the engine with the distributor out. rotate engine to TDC, don't check WHICH TDC, and align the rotor with #1. 50/50 chance of getting it wrong. Easily preventable, but it happens to lots of folks. DAMHIK
PostPosted: Mon Dec 19, 2005 8:35 am
Yep. When I replaced my distributor after accidentally breaking several teeth off the distributor, I installed it way off. Had the engine spit a foot-long jet of flame out the carb air horn, too.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
 Post subject: startup woes
PostPosted: Mon Dec 19, 2005 11:27 am
Ice, thanks for the suggestion about the mixed signals to the two coils. Im not sure how it coud do this, but worth investigating. About the distributor timing, Dan's right, it has no slot, so theres a tooth by tooth choice and I have tried them all. I since have reestablished TDC and aligned the distributor again.
Thanks for the comments, open to new thoughts..
..too many vehicles and a son's college tuition.
PostPosted: Mon Dec 19, 2005 11:41 am
You said you replaced the distributor start and run pickups, did you-check their air-gaps? I do not have the spec near me, but setting them to .008" (as close as you can get both of them to that) should eliminate the air gap as a problem.
IIRC the engine will still run with a bad run pickup (runs off the start pickup in limp mode) but will not start or run with a bad start pickup. :?
PostPosted: Mon Dec 19, 2005 12:22 pm
True. This needs to be done with a nonmagnetic feeler gauge—a brass or plastic one. A regular steel one won't do. If you haven't got a brass one, you can use a business card to get it in the close ballpark of 0.008".
It gets hard to start with a faulty start pickup, but if the reluctor just happens to pass the run pickup after you've released the key, it'll sometimes catch and run.
PostPosted: Mon Dec 19, 2005 12:23 pm
Per my '83 FSM...
Start Pick-up
1 Align one reluctor tooth with pick up coil tooth.
2 Loosen pick up coil hold down screw.
3 Insert .006" non-magnetic feeler gauge between reluctor tooth and pick up coil tooth.
4 Adjust air gap so that contact is made between reluctor tooth, feeler gauge and pickup coil.
5 Tighten hold down screw.
6 Remove feeler gauge. No Force should be required in removing feeler gauge.
7 Check air gap with .008" feeler guage. A .008" feeler gauge should not fit into air gap. Do not force feeler gauge into gap.
Run Pick-up
3 Insert .012" non-magnetic feeler gauge between reluctor tooth and pick up coil tooth.
7 Check air gap with .014" feeler guage. A .014" feeler gauge should not fit into air gap. Do not force feeler gauge into gap.
AKA Ice Titan
PostPosted: Mon Dec 19, 2005 2:00 pm
Is it not acting like it wants to start at all, or does it act like it starts when cranking, and then dies when you move the key to the "run" position?
PostPosted: Mon Dec 19, 2005 3:22 pm
This sounds strangely familiar like a run-in I had one time with a 78 Volare 225 with a bad ballast resistor...... :?
63 Valiant 200 Signet Convertible 170/
63 Dart, 225/
68 A100 Pick-up 225/
2006 Mitsu Raider Quad Cab (Dakota) Mopar 4.7L
1992 Dodge Stealth RT (My Mid-Lifer) 3.0L 24V
PostPosted: Tue Dec 20, 2005 7:13 pm
Per my '83 FSM...
Yes, have done this too - regap at .008, and .0012. Found these specs in the Haynes repair manual.
cstrker.. you asked if it it acts like it is trying to start. Yes, it seems liked like it is close to starting, but just out of reach. As the key is moved to run, it gives a final cough and dies.
this model doesn't have a ballast resistor, it seems the earler schematics show them, but not the '82.
PostPosted: Tue Dec 20, 2005 7:49 pm
I had a very similar situation on my '82 D150: acted like it almost started, had spark as it was cranking, but it just wouldn't run. Turned out to be an ignition switch w/ an intermittently bad "run" position so it wouldn't get fire after you stopped cranking. It's been my expereince that you can have the gap on the pick-up coil grossly misadjusted and it will still atleast run (although badly).
