It is currently Sat Jun 13, 2026 9:53 pm
 Post subject: gas cap
PostPosted: Sun Dec 25, 2005 8:07 am
Car Model: 1974 W100; 72 Dart
the 'parts list' on the home page won't open for me and the archives search has been fruitless.
i know there is a stant # gas cap that fits my 65 b-cuda, but i can't seem to find it. anyone out there able to enlighten me?
thanks,
sb
PostPosted: Sun Dec 25, 2005 9:25 am
Stant G27 non-locking or G85 locking. Both of them are discontinued. Layson's has overpriced repros. I'm working on a more cost-effective solution.
PostPosted: Sun Dec 25, 2005 3:09 pm
A red shop rag???????????
:twisted: :lol: :shock:
PostPosted: Sun Dec 25, 2005 3:41 pm
Classic. :mrgreen: :mrgreen:
PostPosted: Sun Dec 25, 2005 8:38 pm
Naw, a blue paper shop towel. Almost as good, a whole lot cheaper, and easier for the delinquents to light.
Seriously, I'm working on a more cost-effective gas cap solution.
 Post subject: shoot
PostPosted: Sun Dec 25, 2005 8:54 pm
oh well, i guess my blue shop rag will have to do for now. i hope you come up with something. i will delve into this deeper as well.
sb
 Post subject: Gasket
PostPosted: Mon Dec 26, 2005 1:04 am
What about replacing the gasket on your existing one????
PostPosted: Tue Dec 27, 2005 5:59 am
Once you install a rag for a gas cap it is no longer a rag. It is now known a gas tank filler neck pressure release filtration device or a fuse.
PostPosted: Tue Dec 27, 2005 8:35 am
nice. no fuel in the tank right now, so its not much of a fuse, just a small animal and dust deterent for my newly boiled out fuel tank.
actually i have NO cap at all. when i picked the car up out of a back yard, it had no gas cap. i am now dangerously close to getting the car back on the road and need a gas cap.
sb
PostPosted: Wed Dec 28, 2005 8:57 am
Not an ideal fix but this has been working for me - I got a locking gas cap and whittled/grinded down the soft metal insert until it fit. It still locks, and doesn't look too bad.
Steve
1966 Dodge Dart GT
 Post subject: part #
PostPosted: Wed Dec 28, 2005 10:50 am
steve
what car do you have that gas cap on?
what part # did you use to modify to fit? i don't mind massaging the thing to get it to fit, just want to keep crap (other than gasoline) out of my gas tank! oh yeah, and keep gas in there.
sb
PostPosted: Wed Dec 28, 2005 1:26 pm
Hi SB,
This is for my '66 Dart, which I think has the same size filler neck as your '65 Barracuda. Lemme take a look at it when I get home tonight and post the part number (I'm at work right now). I think it's a Stant. Works pretty good, it's just a pain to shave it down to fit the filler neck.
Steve
PostPosted: Wed Dec 28, 2005 9:29 pm
OK, just took a look at the cap and I have to admit it doesn't fit as well as I remember (car's been in storage while I do engine work). The biggest problem is that it's too loose in the in-and-out direction. The catch tabs, the tabs that extend and retract when the key is turned in the cap, are located too far into the neck. This means that you can pull the cap out about 1/4" before the locking tabs catch on the filler neck lip. This is kind of annoying, I wish it was a snugger fit. But it locks and stays put, so it's somewhat secure.
There's no brand name or part number on it; I guess I was wrong about it being a Stant. It's probably just a cheapie, I picked it up at Kragen about 3 years ago. It's big, about 3 1/4" in diameter and does fit nicely into the recess in the body around the filler neck. Sorry I couldn't provide more info, but if you can find a cap whose inside diameter can be shaved down, it might be worth a shot.
Another potential option: I was just at Kragen and the Fram catalog shows part # RG85 as fitting our cars. They didn't have it in stock, it may be discontinued too, but might be worth a look. I think it was non-locking. Hopefully Fram gas caps are better than Fram oil filters!
Steve
PostPosted: Wed Dec 28, 2005 9:35 pm
Oops, previous post is mine :oops:
Steve
PostPosted: Wed Dec 28, 2005 10:14 pm
As far as I and the Fram website know, Fram don't make or sell fuel caps. "RG85" makes me wonder, 'cause the old (now discontinued) Stant number for the locking cap to fit '60-'66 A-bodies was G85.
In any event, I'll try to speed up my fact-finding for you. If all goes well, the gas cap problem will be solved soon.
