It is currently Tue Jun 02, 2026 3:16 pm
 Post subject: Wiper Linkage Bushings?
PostPosted: Tue Jan 24, 2006 2:18 pm
Hi,
I have a 73 Duster and I need the three bushings that hold the wiper lingage onto the arms. Conveniently, they all went away at the same time...in the rain. Also, where can I find a gasket for where the wiper pivots go through the body near the base of the hood?
Thanks alot,
Jon
PostPosted: Tue Jan 24, 2006 3:15 pm
jon-
contact schumacher for your wiper pivot seals and gaskets. he sells them as a kit for around 12 bucks. fro your wiper bushings, look in the "help" section of your local parts store. i have bought them from autozone/advance before but i'm not sure what the part number is or what years they fit. if you don't see them, ask to see the catalog behind the counter.
-james
PostPosted: Tue Jan 24, 2006 3:55 pm
The pivot bushings you're after can be had in the "HELP!" small parts line carried by many parts stores.
PostPosted: Tue Jan 24, 2006 6:23 pm
Thanks alot...didn't even think about Advanced possibly stocking something I needed...I'll give them a try tomorrow...
Anybody around VaBeach looking for a good running Super Six and 904...?
Jon
PostPosted: Tue Jan 24, 2006 9:11 pm
To make them easier to install, soak those new nylon bushings in HOT water a while to soften a bitj. Use a pair of channel lock pliers to press them into place, and fill the sockets with white lithium grease before snapping the linkage together.
Schumacher Creative Services http://www.engine-swaps.com has the wiper pivot seal kits. They come with a pair of grease zerts you can install in the base of the pivot to allow you to keep it greased. My last catalog offers the A-body kit for $11.50, plus $4.50 shipping.
Jerry
PostPosted: Tue Jan 24, 2006 9:48 pm
Personally, I've found the easiest way to put them in is just to squeeze them in using a c-lamp and a socket that just fits around the bottom. I think it was a 9/16, but I could be wrong.
PostPosted: Wed Jan 25, 2006 9:42 pm
Does anyone have a part number from Advanced? All they had today was some larger ones for a Camry or something...
Jon
PostPosted: Wed Jan 25, 2006 10:55 pm
I have gotten the plastic/nylon bushings from yearone.com before pretty reasonable too IIRC. Just go to their website.
Flyin' Brian
"Sixy Beast"
PostPosted: Thu Jan 26, 2006 5:14 am
The linkage bushings from Motormite (Help), no longer come in a package for Mopar, only. It is an assortment, that includes two Mopar bushings, that means you would need two packages. Don't have the part number handy, but can get it later, after I go to the shop.
Also, my local Dodge dealer has them in stock. Close to the same price, and I think better quality. Mopar part number 3799089
PostPosted: Thu Jan 26, 2006 7:18 am
Napa also sells the bushings in little packs of two.
82 D150-225/727
02 Dakota-3.9/5 speed
