It is currently Sun Jun 14, 2026 11:27 pm
 Post subject: help from the experts
PostPosted: Sun Jan 29, 2006 11:31 am
alright kids,
i have just rebuilt my 225 .060 over and stock cam pretty much. i put 302 ford intake valves and a 289 exhaust valves. new springs and all that.
i have a super six manifold and a carter bbd. this seems kinda strange but this motor is really thirsty. i would rejet it but my dad has a brand new 390 holley 4 bbl he just bought and said if i needed it i can have it
i want to use it and i already bought the adapter. what is the best way to dial this carb in. will i net to rejet it. i would like mpg but im a 17 year old who really wants the smiles rather than the mpg. maybe small primaries/huge secondaries. i dont know
thanks for reading
dustin
 Post subject: carb adaptor
PostPosted: Sun Jan 29, 2006 5:29 pm
those 2/4bbl adaptors dont work very will, better cutting and welding a new 4bbl top for cast intake or finding a 4bbl alumium one. you will need to jet the carb to match your comb. have fun. :D
PostPosted: Mon Jan 30, 2006 4:18 pm
ok guys
i bent a rod after the first hour of running
i used the og rods
is this normal or is something seriously wrong
any thoughts?
PostPosted: Mon Jan 30, 2006 5:57 pm
dan?
PostPosted: Mon Jan 30, 2006 6:26 pm
wow u were just tunning and bent a rod :shock: ...thats bad what year of block/internals is it
Cuda Progress :D
The dart as it sits now :(
PostPosted: Mon Jan 30, 2006 8:35 pm
What type of "rod" did you bend? A push rod or a connecting rod?
PostPosted: Tue Jan 31, 2006 3:40 am
i have a stock cam and i bent a pushrod
we were off doing something else while the car was running and it sounded like it locked up
just shut off
so we turn around and try to start it back and nothing
so we pulled the valve cover and #3 rocker is off pushrod
pulled it and its bent
they are the original pushrods would this be common since i redid the head with new springs and it was too much for the pushrod or what?
only shaved the head .030 so its shouldnt be too much right?
PostPosted: Tue Jan 31, 2006 6:09 am
Did you get the rocker shaft mounting hold-downs on the shaft in the correct order? That one got me - they look like they're all the same size, but they're not. I put a too-long one in the wrong space and it pinched a rocker so it stayed open.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Tue Jan 31, 2006 5:20 pm
alright pulled the head and an intake valve seized in the guide (not reallly seized but gaulded) so that is what bent the pushrod
at the machine shop tonight and i am putting it back together tomorrow night
thanks for the responses
PostPosted: Wed Feb 01, 2006 4:06 am
That was kinda what I figured you'd find. You do not have near enough valve spring to bend stock pushrods. Make sure all your rockers are oiling when you start it back up. :shock:
PostPosted: Wed Feb 01, 2006 10:27 am
what happened what on the very left and right ends of the rocker assembly what that we used the wrong bolt so it was starved for oil
we have now fixed the problem and i hope to take her out when i get home from school
right now im sitting in class trying to pretend like im doing something but i would rather be slanting
