It is currently Sat Sep 19, 2026 2:57 pm
PostPosted: Thu Feb 02, 2006 9:29 am
Does anybody know where I can find an OEM washer reservoir for a 66 Valiant? I doubt it, but it's worth a shot.
-OR-
I've also seen reservoir bags that can be used if the original can't be found. Where do I find these? Who makes them and who sells them?
PostPosted: Thu Feb 02, 2006 10:50 am
The '65-'69 washer reservoir can be had from the usual reproduction-parts sources. Year One part number BH141, feel like spending $52 on it?
The '70-up reservoir bolts right in place of the smaller '65-'69 item; you can either grab one off a car with pedal-pump washers or get the kind with the built-in electric pump, which eliminates the noise and leaks of the '64-'69 external metal electric pump.
