It is currently Fri Jun 19, 2026 7:33 pm
 Post subject: Steering wheel Match up
PostPosted: Fri Feb 03, 2006 3:26 pm
I'm going to be spending some time in a wrecking yard tomorrow And while i'm there, I thought that it would be a good idea to replace my un-safe rickety old steering wheel with a less decayed one.
What steering wheels are compatible with a 64 valiant?
As always Thanks
PostPosted: Fri Feb 03, 2006 3:41 pm
Your wheel may be ugly, but it's probably not unsafe. Under the cracked plastic is steel bar.
A '62-'66 A-body steering wheel will be a direct/correct replacement; later steering wheels can be installed and made to work.
PostPosted: Fri Feb 03, 2006 4:38 pm
I used a 69 wheel on my 65,,,,direct replacement.
