It is currently Fri Jan 02, 2026 5:12 pm
PostPosted: Fri Feb 24, 2006 7:08 am
i'm not sure if anybody has seen this, so i thought i'd post a link. it looks pretty interesting. i know there are cheaper ways to make the swap, but this is new stuff except for the alternator and it appears to be pretty much plug and play.
http://www.uscartool.com/
you'll have to select "dual alternator conversion kit" from the menu on the left.
-james
PostPosted: Fri Feb 24, 2006 10:38 am
All new stuff except for the alternator
That's the problem. Remanufactured = junk.
PostPosted: Mon Feb 27, 2006 12:42 pm
Some rebuilds last longer than others. It's no big deal- It's a light unit, takes 15 minutes to replace with the right tools, and the ammeter will indicate failure pronto- I say go for it and keep a spare in the trunk- I keep extra hoses, belts, fuel pump, water pump, starter, tools, etc. there anyway.
PostPosted: Mon Feb 27, 2006 9:49 pm
Suit yourself; I use quality parts that probably won't die, rather than dubious and unpredictable ones that probably will, so I don't have to keep a rolling junkyard in my trunk. (That doesn't mean I don't, just that I don't hafta! ;-) )
PostPosted: Mon Feb 27, 2006 10:29 pm
...my life is a rolling junkyard! :D
D/W
If it ain't broke, fix it!
PostPosted: Tue Feb 28, 2006 3:58 am
D/W
You should see my garage! :shock:
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Feb 28, 2006 5:24 am
D/W
I can't be boxed in by no stinkin' garage! ;)
D/W
PostPosted: Tue Feb 28, 2006 7:32 am
D/W
D/W
Land must be cheaper, or neighbors more understanding in Georgia. :lol: Maybe both...
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Feb 28, 2006 8:15 am
Maybe a little, but still it's the same all over. That's why I keep all my junk on the move! ;)
D/W
PostPosted: Wed Mar 01, 2006 8:13 am
$149 bucks!!!!!!!!! I did the same thing with j/y parts on my slant more than 3 years ago for less than $40, and still no problems with it. I guess maybe I just got lucky.
I'd tell him to go take a dump for that price, but that's just me.[/b]
PostPosted: Wed Mar 01, 2006 12:05 pm
i've done it for free with stuff from a $100 parts car i bought for the disc brakes and lbp axle. like i said there are cheaper ways to do it and you don't have to buy their reman alternator. the real cheap way out is to buy an electronic regulator (standard p/n vr-1000 i think?) that swaps in place of the factory points type and you're there. the second field wire is just a ground, so you're not really gaining anything there.
the thing that i thought was nice is the wiring is all new and it plugs in. for guys with cars like my '63 valiant this is a real godsend as the wiring is brittle and needs replacing anyway.
-james
PostPosted: Wed Mar 01, 2006 12:52 pm
...it's alwez best doin' it for free! ;)
D/W
Users browsing this forum: Bing [Bot] and 6 guests
