It is currently Sat Jan 03, 2026 9:29 pm
 Post subject: Upgrading Wiper Motor
PostPosted: Wed Mar 01, 2006 7:12 am
Is it possible to easily upgrade my one speed wiper motor(64 dart), to a two or three speed?
thanks,
josh
64 Dart 170 /6
PostPosted: Wed Mar 01, 2006 5:47 pm
The optional wiper setup in '64 was a variable-speed setup. Works like a dining room dimmer switch. You need the special switch, the special motor, the 4-wire harness between the switch and motor, and—pay attention, this is important—all the pieces that connect the wiper motor's crank arm to the wiper transmission bar links. They are not the same as with the single-speed setup. Any '64-'66 A-body with variable-speed can contribute the motor (many '64-'65 cars have it, and I don't think I've ever run across a '66 without it). The right switch for your '64 is '64-only, so it's "go fish" on the used-parts market, but a '65-'66 switch can also be made to work without much difficulty. The hookups are the same, it's just the shaft length and configuration, and provisions for electric screenwashing, that are different.
PostPosted: Thu Mar 02, 2006 9:29 am
Thanks Dan! I really appreciate the thoroughness of your replies. I can't even count the number of times your informative posts have helped me out. I don't mean to make this a forum love-fest, but sometimes a simple thank you just doesn't seem appropriate.
-josh
64 Dart 170 /6
PostPosted: Thu Mar 02, 2006 9:51 am
Thanks for the "thanks"!
