It is currently Mon Dec 29, 2025 10:20 pm
 Post subject: Super six swap question
PostPosted: Thu Aug 05, 2004 1:01 pm
Ok i found a whole super six setup and i was planning a swap i was wondering if the exhaust will match up or will i have to run open to the shop, I know there is a 1/4 size differance but i realy didn't have a chance yet to check the angles.
PostPosted: Thu Aug 05, 2004 1:24 pm
the opening on both manifolds is the same size 1 7/8" but there is a slight angle difference between the 2. to get it to seal I just took the bolt out that holds the exhaust pipe bracket to the trans. then snugged both exhaust manifold to pipe nuts
