| Slant Six Forum https://www.slantsix.org/forum/ |
| Super six swap question https://www.slantsix.org/forum/viewtopic.php?t=10026 |
| Author: | golembieski [ Thu Aug 05, 2004 1:01 pm ] |
| Post subject: | Super six swap question |
Ok i found a whole super six setup and i was planning a swap i was wondering if the exhaust will match up or will i have to run open to the shop, I know there is a 1/4 size differance but i realy didn't have a chance yet to check the angles. |
| Author: | 70valiant [ Thu Aug 05, 2004 1:24 pm ] |
the opening on both manifolds is the same size 1 7/8" but there is a slight angle difference between the 2. to get it to seal I just took the bolt out that holds the exhaust pipe bracket to the trans. then snugged both exhaust manifold to pipe nuts |
