| Slant Six Forum https://www.slantsix.org/forum/ |
| idle issue??? https://www.slantsix.org/forum/viewtopic.php?t=10480 |
| Author: | slantswinger [ Thu Sep 23, 2004 8:20 pm ] |
| Post subject: | idle issue??? |
i have a 75 swinger with a super six setup and an open 6 to 1 header. i can't get this thing to idle. the only time i got it to idle was after the engine warmed up for a while from trying. then it idled. is the engine not idling because of the lack of back pressure or is there another possible reason? i don't plan to keep the exhaust open but i would like to have the car running properly wen i get the exhaust system next week. thanx in advance. |
| Author: | stinky mctinkerpants [ Thu Sep 23, 2004 8:36 pm ] |
| Post subject: | idle hands.... |
sounds too lean, it might be less backpressure than stock sup 6 exhaust manifold so it needs a richer mix, how was it before the header? is there any smoke? |
| Author: | slantswinger [ Thu Sep 23, 2004 8:39 pm ] |
no smoke it runs real clean i didnt run it with the stock exhaust manifold cuz i put everything on together. |
| Author: | slantswinger [ Thu Sep 23, 2004 8:48 pm ] |
| Post subject: | Re: idle hands.... |
Quote: sounds too lean, it might be less backpressure than stock sup 6 exhaust manifold so it needs a richer mix, how was it before the header? is there any smoke?
on the bbd card theres two idle mixture screws should they be adjusted identically? how many turns do you think i should set them at?? (im new to carb tuning)
| Author: | stinky mctinkerpants [ Thu Sep 23, 2004 10:04 pm ] |
| Post subject: | hmm lets see |
for some reason my signature says super six but i am actually rolling a single barrel holley. i am although about a week away from getting a sup 6 setup thanks to another slanter. i have although done this with many other carbs, i am going by basics. get the car warm enogh to idle if you can try 1/2 turn counter clockwise each see if it ups the idle, if it lowers it go the other way. i use 1/2 turn increments some use 1/4. if your car is running good it might be your choke adjustment also, if your car idles good warm than it most likely is. I am sure the more experienced slant tuners have a good formula and some standard settings. the articles section of this forum is loaded with info, check it out |
| Author: | slantvaliant [ Fri Sep 24, 2004 6:18 am ] |
That line under your member name (Super Six, Hyperpak, etc) changes with the number of posts. It's just one of the fun features of this forum, and I like it! Personally, I still have my BBS in place, although a BBD and its two-barrel manifold are waiting on the shelf. |
| Author: | slantswinger [ Sun Sep 26, 2004 2:53 pm ] |
today i ordered a flowtech purple hornies glasspacked header muffler and i should be getting it in by tuesday. any more sugguestions on my idle problem? |
| Author: | Pierre [ Sun Sep 26, 2004 5:42 pm ] |
I couldn't get my slant to even stay running let alone decently idle with open clifford shorty headers. It took a number of starts to get it on the flat bed towtruck that took it to the exhaust shop. |
| Author: | slantswinger [ Sun Sep 26, 2004 7:22 pm ] |
it idled fine after you got the exhaust? |
| Author: | Pierre [ Sun Sep 26, 2004 7:28 pm ] |
Affirmative. Without an exhaust, I would have to keep the pedal down or the motor would just die, and it was a pain to get it started. Once the exhaust was on, started on first crank with no pedal at all. |
| Author: | slantswinger [ Sun Sep 26, 2004 7:31 pm ] |
awesome thanx for the help |
| Author: | Slant6Ram [ Mon Sep 27, 2004 5:51 am ] |
| Post subject: | Choke? |
If you didn't connect the choke up correctly, you'd have a heck of a time getting it to idle cold, but it would run perfect when warmed up. Is the choke flap closed when cold starting? |
| Author: | slantswinger [ Mon Sep 27, 2004 2:03 pm ] |
funny you mentioned that i installed a manual choke because theres was nowhere, to my knowledge, to bolt the automatic choke because of the header. |
