| Slant Six Forum https://www.slantsix.org/forum/ |
| Where to Start https://www.slantsix.org/forum/viewtopic.php?t=10506 |
| Author: | DAJUJ [ Mon Sep 27, 2004 6:52 am ] |
| Post subject: | Where to Start |
Brought home the bone stock 225/auto 65 Valiant this weekend. It's future use is various "cruises" in the local area...no drag strips in the near future either. But...other than a good tuneup, etc., what upgrades to the engine would you suggest for a little more performance (the chrome valve cover looks good though!)? |
| Author: | Reed [ Mon Sep 27, 2004 7:32 am ] |
(1) electronic ignition (2) larger exhaust system (3) larger carb (you will be limited by your throttle linkage--you may want to convert to a cable style) |
| Author: | DAJUJ [ Mon Sep 27, 2004 6:39 pm ] |
| Post subject: | Where to Start Part II |
Reed: Already have upgrade to ignition system installed. Guess the next step is exhaust or intake. I don't really know which to begin with. Ideas? |
| Author: | 63gtcv [ Mon Sep 27, 2004 6:44 pm ] |
| Post subject: | ditto |
those are the only upgrades I have on my dart. The difference in the way it runs is amazing. Runs great,starts great, sounds good too with Dutra duals and turbo mufflers. |
| Author: | Matt Cramer [ Tue Sep 28, 2004 9:39 am ] |
Your typical carb upgrade options are a Super Six (junkyard two barrel that makes a decent improvement) or a 390 cfm four barrel Holley on an Offenhauser or Clifford manifold. Other options include two stock carbs on a special Offenhauser manifold; Mopar's M1 two barrel kit; Pro Line Fuel's one, two, or three Weber conversions (the single one uses your existing manifold); or certain oddities from Australia that occasionally pop up on Ebay. Three Webers would be a bit wild for street use, and there's some debate about whether a four barrel is too big for a stock slant. |
