It is currently Tue Dec 30, 2025 12:57 am
 Post subject: idle issue???
PostPosted: Thu Sep 23, 2004 8:20 pm
i have a 75 swinger with a super six setup and an open 6 to 1 header. i can't get this thing to idle. the only time i got it to idle was after the engine warmed up for a while from trying. then it idled. is the engine not idling because of the lack of back pressure or is there another possible reason? i don't plan to keep the exhaust open but i would like to have the car running properly wen i get the exhaust system next week. thanx in advance.
 Post subject: idle hands....
PostPosted: Thu Sep 23, 2004 8:36 pm
sounds too lean, it might be less backpressure than stock sup 6 exhaust manifold so it needs a richer mix, how was it before the header? is there any smoke?
anything worth doing is worth re-doing, again and again and again...........
PostPosted: Thu Sep 23, 2004 8:39 pm
no smoke it runs real clean i didnt run it with the stock exhaust manifold cuz i put everything on together.
 Post subject: Re: idle hands....
PostPosted: Thu Sep 23, 2004 8:48 pm
on the bbd card theres two idle mixture screws should they be adjusted identically? how many turns do you think i should set them at?? (im new to carb tuning)
 Post subject: hmm lets see
PostPosted: Thu Sep 23, 2004 10:04 pm
for some reason my signature says super six but i am actually rolling a single barrel holley. i am although about a week away from getting a sup 6 setup thanks to another slanter. i have although done this with many other carbs, i am going by basics. get the car warm enogh to idle if you can try 1/2 turn counter clockwise each see if it ups the idle, if it lowers it go the other way. i use 1/2 turn increments some use 1/4. if your car is running good it might be your choke adjustment also, if your car idles good warm than it most likely is. I am sure the more experienced slant tuners have a good formula and some standard settings. the articles section of this forum is loaded with info, check it out
PostPosted: Fri Sep 24, 2004 6:18 am
That line under your member name (Super Six, Hyperpak, etc) changes with the number of posts. It's just one of the fun features of this forum, and I like it!
Personally, I still have my BBS in place, although a BBD and its two-barrel manifold are waiting on the shelf.
PostPosted: Sun Sep 26, 2004 2:53 pm
today i ordered a flowtech purple hornies glasspacked header muffler and i should be getting it in by tuesday. any more sugguestions on my idle problem?
PostPosted: Sun Sep 26, 2004 5:42 pm
I couldn't get my slant to even stay running let alone decently idle with open clifford shorty headers. It took a number of starts to get it on the flat bed towtruck that took it to the exhaust shop.
PostPosted: Sun Sep 26, 2004 7:22 pm
it idled fine after you got the exhaust?
PostPosted: Sun Sep 26, 2004 7:28 pm
Affirmative.
Without an exhaust, I would have to keep the pedal down or the motor would just die, and it was a pain to get it started. Once the exhaust was on, started on first crank with no pedal at all.
PostPosted: Sun Sep 26, 2004 7:31 pm
awesome thanx for the help
 Post subject: Choke?
PostPosted: Mon Sep 27, 2004 5:51 am
If you didn't connect the choke up correctly, you'd have a heck of a time getting it to idle cold, but it would run perfect when warmed up.
Is the choke flap closed when cold starting?
1980 Aspen 225 super six
PostPosted: Mon Sep 27, 2004 2:03 pm
funny you mentioned that i installed a manual choke because theres was nowhere, to my knowledge, to bolt the automatic choke because of the header.
